Used Mixed Gasoline( Gas & Oil) on Lawn Mower...what do I do?
Old 07-08-14, 08:26 PM
L
Okay, I accidently poured the mixed gasoline and oil combo (used for weed eaters) into the lawn mowers gasoline tank. The lawn mower already had half a tank of good gasoline. The mower ran fine but did not know I did this unti lafter the fact later in the day. What should I do?? Please help. If I have to drain the gas...how should this be done.
Thanks.
Old 07-08-14, 08:31 PM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
If it's running fine I would let it go. As far as I know a little extra lubrication won't hurt any.
Old 07-08-14, 09:24 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Fill it back up with regular gas to help dilute it. Also try to shake the mower to agitate the gas before you use it next. When you pick up a weedeater or blower, by the time you start it you've already agitated it somewhat, you won't get that with a mower. You want to keep the oil and gas mixed up.
Old 07-08-14, 11:55 PM
cheese's Avatar
Received 110 Upvotes on 100 Posts
Use it... no worries. It's fine to use any time.
Old 07-09-14, 01:44 AM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
Might smoke a little more till gas used up but should not hurt anything.
Old 07-09-14, 03:03 AM
Received 740 Upvotes on 646 Posts
The worst it can do is foul the sparkplug. I'd refill with the correct gas and not worry about it
Old 07-09-14, 04:33 AM
O
Received 8 Upvotes on 7 Posts
Don't tell my lawnmower or it will want some oil too.
Just dilute it down. That oil was meant to burn in an internal combustion engine. No problem.
