How does fuel stop when carb float rises?
So, I get the principle that the carb float acts like a toilet float but when it blocks the inflow of fuel, the... the fuel pump is still going so why doesn't fuel pour out of the pipes or pump?
And to elaborate a bit more... The float is rather large so it can exert a pretty decent up force. The float is also mounted at the end of the float arm while the needle valve is located very near the pivot point. This provides a lot of mechanical advantage. And lastly, the needle valve has a very small surface area. Even high pressure fuel acting on such a small surface (hydraulics) can not exert much force so it's relatively easy for the needle to remain sealed against the pressure.
