Gas-powered pressure washer pump stuttering
I have a typical direct-drive gas-powered pressure washer--a Campbell Hausfeld 3200psi with Annovi Reverberi pump. A problem this season is short stutters in the output. Too brief to be engine related, the engine reacts to the pressure changes but isn't causing them.
I assume the pump head has piston(s) that do the pumping--what could cause the pressure to drop out rapidly--and even quit to the point of just being a gentle mist from time to time?
Incoming water seems to be steady, no leaks or other pso found.
Sounds like air in your hose or water line. If you are using a long hose, it can take a long time to get all the air out.
I know how air in the line behaves--I would get puffs of air out the nozzle and it's more of an interruption than a quick pressure drop.
I'm going to have to take it apart. Looking at diagrams online I assumed the engine & pump were connected by a keyed shaft. Yesterday I checked the setscrew and it was backed way out. It won't tighten--just seems to go into a void and run out of thread. Maybe I don't have a key in there, the shaft is chewed up or something that's allowing it to slip.
