k301 kohler charging
Old 07-19-14, 06:46 PM
i put a 12 hp k301 kohler on a log splitter everything is hooked up and running know i need to know how to wire it up to charge the battery
Old 07-20-14, 06:22 AM
31YTech's Avatar
Hello Jeff Huffman,
If you have the proper voltage regulator for the engine, All you need is a hot wire in run position ran from the ignition switch through a 30 amp in-line fuse holder to the B+ spade on the regulator.
Good Luck
