MTD Yard- man, lawn tractor drive belt change
Old 07-20-14, 12:00 PM
K
Hello! I have a MTD Yard-man riding lawn tractor that I am trying to change the drive belt on. It is a 604 model series , auto drive, model 13Bu604G501.
The problem I am having involves removing the electric PTO clutch, When I am turning the hex bolt the pulley spins, and I can not see anyway to keep it from turning!
Any suggestion or solutions would be helpful!
Old 07-20-14, 12:29 PM
G
Received 2 Upvotes on 2 Posts
If you do not have an owner's manual, here is a link.
http://www.mtdproducts.com/equipment...&serialNumber=
Old 07-20-14, 03:39 PM
K
Yes I do. Thank you for your reply. Any ideas what the problem might be?
Old 07-20-14, 06:02 PM
G
Hard to tell from the parts sheet but there is usually a bolt head on the blade side of the deck and a nut on the top of the pulley. Wrenching both should break it loose.
Old 07-20-14, 09:17 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
You'll need an impact gun or put a good length of pull rope into a spark plug hole to jam the piston from coming all the way up to block the engine from turning.
