Kohler 18 hp will not start
Old 07-24-14, 07:23 PM
B
I have a SV540s Kohler 18 hp single cylinder engine that will not start unless i spray either gas or starter fluid in carburetor. It runs great after that and will restart on its own UNLESS i let it set for too long, then i have to prime it again. NEW carburetor, fuel pump, spark plug, solenoid on carb, am at a loss. Compression is 71 lbs.
Anyone got any idea what is causing this?
Old 07-24-14, 07:44 PM
cheese's Avatar
Received 133 Upvotes on 122 Posts
Sounds like your choke isn't closing all the way.
Old 07-24-14, 07:46 PM
B
choke is working fine. new carb. i work on mowers and this one has me stumped.
Old 07-24-14, 10:41 PM
cheese's Avatar
Can you see the choke butterfly in the throat of the carb hitting the sides of the throat when it is closed? The reason I'm asking is because I have had to fix this on several of these so far. There is a phillips screw on the linkage that adjusts this.
