wright stander serial #17124
Old 07-26-14, 08:50 AM
N
Received 1 Upvote on 1 Post
I have problem when i start running mower a distance at full throttle it runs out of fuel and dies,it doesnt matter wherther the pto is engaged or not same results. Its a 23 hp kawasaki 61inch.Fuel filter is good and petcock valve under gas tank is wide open,any suggestions?
NelNan3445# voted this post useful.
Old 07-26-14, 10:43 AM
cheese's Avatar
Received 134 Upvotes on 123 Posts
Check fuel flow into the carb bowl.
Old 07-26-14, 02:22 PM
99% of the time the carburetor needs to be removed, cleaned with carburetor cleaner and rebuilt.
It's the ethanol fuel causing the issues.
Once you get it running see if you can find any where local to buy nonethanol fuel or add an additive to counter act the effects of it.
There's dozens of company's making it.
Old 08-03-14, 08:38 AM
N
i took carb apart and rebuilt. Runs great now, thanks for advise
