No Fuel To Small 3.5HP Motor
Old 07-29-14, 06:12 PM
N
Just scavenged a go kart which has a small 3.5hp motor. Spark plug wasn't sparking but I fixed that, the magneto ignition coil had some wires disconnected. Now it looks as though I am not getting fuel to the motor. I drop some fuel directly into the carp and the thing starts but for only a short time before it stops. What should I try?
Old 07-29-14, 07:07 PM
G
Received 23 Upvotes on 22 Posts
Need more info about the motor, manufacturer, model, type, etc. Have a good one. Geo
Old 07-29-14, 07:51 PM
XSleeper's Avatar
Received 1,720 Upvotes on 1,544 Posts
How's that carp like the taste of the fuel? LOL Seriously though, what kind of carb is on it? I'd take it off and make sure the pickup tubes are clear, if that's the type it is. The carb gaskets are usually something you automatically replace on an engine that's been sitting around for a while.
Old 07-30-14, 11:13 AM
N
It's a briggs and stratton model number 091202-0016-01
Old 07-30-14, 12:23 PM
N
There are two holes at the top of the gas tank. One the goes completely inside where the fuel line goes then another which has a shallow cavity and connects to a smaller line on the carb. This shallow cavity does fill up with a small pool of fuel. This cavity can be located by the red rectangle in this picture: Name:  unnamed.jpg
Old 07-30-14, 12:47 PM
G
You probably need to clean the carb and install a rebuild kit Part # 495606. The hole in the square is the reservoir, the diaphram pumps fuel from the tank into it so fuel is available as air passes over the carb nozzle. Have a good one. Geo
Old 07-30-14, 01:21 PM
N
I just took out the idle screw and saw that it is broken. The screen seems to have split and I am not sure if the other part of the screw is still in the hole. What should I do and is this that important?
Old 07-30-14, 04:09 PM
G
Here is a link to the briggs site where you can get and IPL for the motor. Have a good one. Geo
Results
Old 08-01-14, 12:32 PM
N
Just rebuilt the carb and the engine stays running with no problem but still on starts with starting fluid. Any suggestions?
