I have this 5.5 hp Honda water pump that wont run without the choke on
This pump sat up for several years with no use and it wouldnt start. I got the engine to run a minute by bypassing the carburetor so I figured the carburetor was gummed up or worse. I didn't have a lot of time to deal rebuilding it so I just replaced the carburetor with a brand new one. It cranks fine but wont run if I turn the choke off even a slight little bit. Wonder what could be wrong? Any ideas? Thanks.
Oh, I replaced the spark plug too and the air filter and cleaned the gas tank and lines with fresh gas.
This is the pump.
HONDA WMP20XA1 MULTI-PURPOSE WATER PUMP
This is the pump.
It sounds like a carburetor issue. Is the new carburetor the correct one for the engine? Are there adjustable jets on the new carb.?
I bought the carburetor from the business I bought the pump from (Wilson Dismukes), I assume it's the correct one. Comparing the 2 they looked right. Not sure about any jet adjustments. I see 2 adjustments. #5 says its a "SCREW SET, PILOT". #10 says it's a "SCREW, THROTTLE STOP". Those are the only adjustments that I can see. I played around adjusting both of them with no luck Here's a diagram of the carburetor.
Lawn Mower Parts, Small Engine Parts & Much More! | PartsTree.com - Briggs, MTD, Toro, Cub Cadet, Husqvarna, Troy-bilt...
Oh, when I pull the starter rope it fires up with one pull and is very easy to pull etc.. with no resistance. I do see one thing. There are 2 gaskets on this diagram but the parts guy only gave me 1. Maybe I could take it back apart and replace those to insure there's no air getting in there.
Check the plastic/bakelite insulator behind the carburetor for cracks while you're checking. I've run into that a time or two.
I took the carburetor back off this afternoon, along with that hard plastic insulator. Nothing was damaged or cracked. I replaced the #15 spacer that goes between the breather housing and the carburetor and the other gasket (#14). Put everything back together and it cranks very easy on the first pull but still wont run without the choke all the way on. I ran water through the pump while it was running and placed the palm of my hand over the intake for a second and it has plenty of suction and didn't seem to strain the engine. Wonder if it could be something in the engine? hmmm.
I worked on it but didn't really get anywhere. I took the old carburetor apart and cleaned it very good and put it on the pump but the pump would only run for a minute before shutting off. It would crank up easy but seemed like it couldn't get a good supply of gas. If I waited a minute it would crank up fine again but only run for a brief time. Ended up putting the new carburetor back on and the same thing. It would crank easy and run with choke on only. I cant figure it out. Maybe I'll take it to the shop and see what they say.
Are you certain there is a good fuel flow from the tank to the carburetor. Maybe you have a partially blocked or pinched fuel line.
Yeah, the fuel is freely flowing from the tank to the carburetor. When I had the carburetor off I sprayed cleaner through all the passages and jets and opening and everything looked ok with nothing clogged or restricted that I could tell. Inspected the float and everything generally looked normal.
