Fuel line won't fit on tank fitting
Old 08-01-14, 02:29 PM
D
Received 1 Upvote on 1 Post
Hi All - Easy question that I assume there is a trick for. The fuel line for my generator at the tank end was cracked. So i removed it and cut it before the crack. Now i need to put it back on the piece that goes into the tank.
But for the life of me i can't get that sucker back on the metal nipple piece. I've tried to use a lighter to soften the line and that didn't seem to do much.
Is there a trick to doing this? More heat then a lighter perhaps...
Old 08-01-14, 02:39 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
The line has probably hardened up and won't flex enough. You might try a little WD40 or similar sprayed/rubbed on the nipple.
I'd probably replace the whole line if possible.
