Troy Built Pressure Washer Won't Start at all, Bad Switch???
Old 08-08-14, 09:09 PM
T
I purchased a twice-used Troy-Built 3000 PSI Pressure Washer from a neighbor who was moving. I saw the tool work previously. It has the Honda GVC 190 motor. New fuel, good oil, new spark plug. Will not start. Does not even attempt to fire. Followed all directions; switch is "on:, fuel line is "open" choke is full open. Does not even try to start. Crank pulls smoothly and the pressure is relieved from the spray handle. The one thing I notice is the motor reacts the same whether the switch is in the "on" position or the "off". Could it be a bad switch????
Any help is appreciated.
Old 08-10-14, 05:46 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Have you checked for a good spark?remove the plug install the plug wire and ground the plug to the engine block and try to start and see if there is a good spark.
Also is the plug wet or dry when you remove it?
Geo
Old 08-11-14, 08:44 PM
T
Thanks for the reply. I have tested both. The plug is dry when I remove it and we tried testing the plug against the block and no spark.
Old 08-11-14, 09:17 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
Unplug the kill wire from the coil and check for spark again.
