Poulan riding mower leaking fuel at the carb
Old 08-16-14, 03:46 PM
H
Hello,
I have a older Poulan 450-420. Model number is HD14542b. It is leaking fuel right at the carb. It looks like there is a plastic elbow coming out of the carb and the fuel line attaches to this elbow. It is leaking fuel right at this elbow on the carb side. I don't mind tearing the carb apart but my farm is 2 hours away so I need to know if that part is repairable or any tips or tricks before I get there.
Thank you.
Old 08-16-14, 07:07 PM
A
Received 4 Upvotes on 4 Posts
Fuel elbow repair
You'll need the engine numbers to get the right parts. You'll need the correct replacement elbow. Than pull off the plastic part & put a little grease into the fitting & tap the hole 10-32 the grease will keep the chips from getting into the carb. take a long 10-32 tap bolt thread a nut onto it place a 1/4" 7/16" deep socket over the fitting thread the bolt into the fitting & use the nut to pull the fitting out. The new fitting is than pressed in.
Old 08-17-14, 12:31 PM
A
If pictures help:
Old 08-17-14, 06:05 PM
H
Thank you. I don't have the puller assembly. Can I make one or is there a work around?
Old 08-17-14, 06:22 PM
A
Puller
The puller is just a long 10-32 tap bolt(has threads the whole length of the bolt), a deep 7/16" 1/4" drive socket, 10-32 nut and washer.
AJ
Old 08-18-14, 08:27 AM
A
Old picture had an error here is the new one:
Old 08-31-14, 11:24 AM
H
I installed an inline fuel shutoff so I don't drain my tank until I get the carb fitting. I think I need to clean the carb as well. Any tricks to that? My craftsman has a bolt on the side to clean it out without tearing it apart. I don't see that on this Poulan.
Is installing the replacment fitting any easier with the carb apart?
Thank you so much for all the help so far.
Old 08-31-14, 12:42 PM
A
It would be best to press in the new fitting with the carb off the engine. So you might as well clean it than too. Need the engine numbers Model Type & Code for carb kit numbers. Take pictures of the linkage before you take it apart.
