Restring Kawasaki trimmer issues
Old 08-29-14, 08:46 PM
Received 1 Upvote on 1 Post
Kt27fra3 trimmer
I am trying to understand how to restring this trimmer head.
It's got an arrow on it pointing left and right. One says left and the other right. How do you know if the bump side or the inside goes left or right?
Last edited by Pilot Dane; 08-30-14 at 05:21 AM. Reason: added [IMG] code to make pictures work
Old 08-29-14, 10:13 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
Generally if you look from above at the head when the engine is running, the line is wound the opposite direction from the inside out looking at the spool from the same view.
Old 08-30-14, 05:23 AM
P
Received 2,190 Upvotes on 1,959 Posts
It looks like that's a universal or replacement spool and you'll have to do what Cheese recommended and look at the rotation direction of your trimmer. Once you know, wound the line, and tested it to make sure you got it right I would use a chisel to scrape off the incorrect lettering so you won't have this problem again in the future.
