poulan pro 25 hp tractor speed control lever
Old 09-04-14, 06:43 PM
H
I've got a Poulan Pro PRGT25H48A model garden tractor that has a cracked trans shifter/speed control lever. Has anybody run across this failure? I am trying to figure out how to get the lever out of the frame for replacement or repair with a welder. Trying to attach a pic of the part. The break is a crack you can see just to the right of the large hole in the frame.
Thanks
Bill
Old 09-05-14, 02:55 PM
D
The lever appears to be riveted on, you will destroy more things trying to get it off, any welder should be able to scab on a repair (using gas brazing) because the lever appears to be too thin for a good weld, and it may only weaken the metal further down the line. But I do see what appears to be a wear shim close to the crack, it will have to be removed or it will melt.
Old 09-05-14, 10:07 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
If I'm seeing the crack correctly, a small mig welder would fix it up just fine. Take it bay a machine shop and they should be able to weld that in a minute or so.
