New PTO Belt For Cub Cadet 2135 Keeps Coming Off
spirittoo's Avatar
OH
09-13-14, 01:41 PM   #1
I had to replace a pto belt on my cub cadet 2135 tractor and I only got one cut out of a new belt, then it kept coming loose. :NO NO NO: It is a spare belt I bought a while ago I had in storage. Is the belt bad or is there I way I can keep it from coming off the pulley? Should I try and find the merchant I purchase it from for a replacement? .
goldstar's Avatar
OH
09-13-14, 01:47 PM   #2
First go over the pulley and belt diagram to be sure all are properly attached. Then check the tensioning pulley. It should keep the belt from flopping around.
Woody
You can trust your car - and a whole lot more - to the man who wears a star.
spirittoo's Avatar
OH
09-13-14, 02:27 PM   #3
How do I do that?
Thank you for posting ... I'm sure I have it properly attached ... I have change several pto belts in the past. Could you tell me which one is the tension pulley and how I can adjust it? I have put on another belt I had in storage and so far it only came off a couple of times, but is maintaining. Is there a bolt or something I have to tighten?
marbobj's Avatar
IA
09-13-14, 04:29 PM   #4
It would be the moveable pulley #1. That pulley is self adjusting since it's a spring tension pulley. All you have to do is make sure it moves freely. The spring holds the tension of the pulley against the belt.
Probably there is some trash or corrosion interfering with the pulley.
cheese's Avatar
GA
09-13-14, 09:34 PM   #5
I think that drawing is showing the wrong belt... The PTO belt would go from the engine to the top of the rearmost pulley in that drawing. I would check that pulley to be sure it isn't tilted enough to cause the belt to ride off of it either because of the deck being tilted too far down in the front, or because of worn bushings in the mounting bracket for the pulley. Also check to be sure the belt is good and tight and the spring at the end of lever #3 is putting tension on that rear pulley keeping the pto belt tight.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
spirittoo's Avatar
OH
09-15-14, 07:44 AM   #6
It is the wrong belt
Cheese is right it is the wrong belt ... my pto belt goes pass the front roller to pulleys on the engine. I'll check the pulleys for trash.
