New carb, old problem
Old 09-18-14, 01:11 PM
Tecumseh 10 hp engine HMSK100 - 159208T on a 20-year-old MTD snowblower. The engine would only run at full choke, full throttle.
The thing was a gift, but I decided to rebuild it and try it this winter. I installed new carb, spark plug, fuel lines, cleaned and lubricated, etc.
Starts with half a pull... but still stalls out when I open the choke even halfway.
My guess would be the idle air adjustment, but I welcome any guidance. Thanks.
BTW, why is there no air cleaner - or even any provision for an air cleaner - on this engine???
Old 09-18-14, 01:18 PM
G
Received 31 Upvotes on 29 Posts
First, most snowblowers don't have air cleaners they freeze up. Second, with the engine running dribble/spray some carb/brake parts cleaner behind the carb along the mating surfaces of the intake, if the engine tempo changes you have an air leak and can take the appropriate action. Have a good one. Geo
Old 09-19-14, 08:45 AM
Thanks. The carb was a bit loose and that made a slight difference, but I had to open the air idle screw a full turn before the engine would run with the choke open. Now it idles at any throttle setting.
