Cub Cadet GT1554 Rider blowing fuses
Old 09-21-14, 05:43 PM
shadowbear's Avatar
Question Cub Cadet GT1554 Rider blowing fuses
I was mowing, hit a low spot in the yard which jarred the mower slightly and it shut off instantly. I had blown a fuse that is under the battery compartment. I've replaced that fuse and blew another one when I tried to start it back up. I checked the wiring cause I assume I'm grounding out somewhere, but I'm at a loss to know where. Any ideas?
Old 09-21-14, 08:04 PM
cheese's Avatar
Received 149 Upvotes on 136 Posts
I would probably suspect a relay given the nature of how it quit. Does it blow as soon as you put a fuse in or when you turn the key on, or when you turn it to start?
