Briggs and stratton won't run
Old 09-22-14, 07:23 AM
G
Hi all
I have a ride on mower with a briggs and stratton 13.5 engine
Model 21b807. Type 0289. B1
It stopped running done all checks and discovered that the bolt holding rocker arm came loose and the rocker arm came loose result the intake pushrod got bent,
Got new pushrod and done the valve adjustment
Intake valve 0.003-0.005
Exhaust valve. 0.005-0.007
And it will start running very rough and then die won't take throttle can anyone tell me if the valve adjustment is correct or if there is some other problem.
Thanks gemburn
Old 09-22-14, 09:33 AM
G
Received 23 Upvotes on 22 Posts
When you adjusted the valves did you have the piston 1/4in past TDC, if not that may be the problem. Have a good one. Geo
Old 09-22-14, 11:27 AM
G
Yeah did exactly that, tcd then a 1/4 on the compression stroke.
Old 09-22-14, 01:19 PM
O
Received 8 Upvotes on 7 Posts
Did you check the bolt on the rocker arm again to ensure that it stayed tight this time. Since it loosened before, there could be a problem with the bolt. I would also want to take a close look inside that valve cover to ensure that everything is still working right (didn't bend another rod).
Old 09-23-14, 12:03 AM
G
No I put lock tight on the bolt, valves are working ok, but when it starts it's very rough won't take throttle at all.
Old 09-23-14, 09:23 AM
cheese's Avatar
Received 110 Upvotes on 100 Posts
Check your valve movement. I'm guessing one of the valves is barely opening.
Old 09-24-14, 12:30 AM
G
Will do, I will let you know how I get on.
Old 09-29-14, 10:53 AM
G
Cheese you were right valve was staying slightly open put in a new one and away it went. Thanks to all who replied.
Old 09-29-14, 08:04 PM
cheese's Avatar
Great, glad we could help and thanks for the update!
