Honda engine
Old 09-28-14, 06:34 AM
Honda engine
Have a GX 160 Honda 5.5 on a home made log splitter, has electronic ignition, oil cut off. Engine will run for 15 to 20 min. then stops, can get it started but only will run for about 5 min. Is it low on oil or an ignition problem? Can I change any of the electronics without takeing it all appart? Thanks
Old 09-28-14, 09:09 AM
G
Received 30 Upvotes on 29 Posts
Try loosening the fuel cap, it may not be venting properly. Have a good one. Geo
Old 09-28-14, 11:50 AM
P
Received 2,121 Upvotes on 1,899 Posts
"is it low on oil?" You tell us. Check the oil level.
If it's not the fuel cap you may have a coil going bad. It works when cold but when it gets hot it starts to fail. Next time it dies and won't start remove the spark plug, attach the plug wire to the plug and hold it against bare metal of the engine and have someone pull the starter cord. If you can't get the spark plug to spark it's likely the coil.
Old 09-29-14, 06:00 AM
Thanks for the info, the oil level insn't marked on the oil dip stick, don't know where the low or full marks are!
Old 09-29-14, 09:00 AM
P
Fill it to the top of the oil filler neck. The manual for your engine is available online.
Old 09-29-14, 10:26 AM
G
Check the manual before adding oil, filling to the top of the oil filler neck will be way overfull on some. Have a good one. Geo
