Intek 15.5 Shakes and farts
Old 10-05-14, 10:48 PM
Hi, Sounds like the timing is out, Starts fine but won't rev and back fires shakes and generally isn't having a good day. I checked the key on the flywheel and its fine. New fuel and the plug's ok. Its a Briggs 285H77 15.5hp on a Countax Ride On. Any help or suggestions greatly appreciated. Cheers
Steve
Old 10-06-14, 06:35 AM
Received 1 Upvote on 1 Post
Rebuild the carburetor and I bet it stops acting up.
Find a place to buy nonethanol fuel, single biggest issue with small engines is ethanol fuel.
Short of that go buy some of the additive to counter act the effects of it.
Any auto store, Walmart, Box store, power tool store will have it.
Old 10-06-14, 07:59 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
How does it idle?
______________
Old 10-06-14, 10:02 PM
So I just gave the carb a clean and blow out and its running much better - to my surprise I thought it was going to be almost deathly.. Still won't make full throttle and now "pops" somewhat but defiantly an improvement so progress is great. It idles kinda ok like rough and "hunts" i think you call it. I'll take the carb off again as it looks like its had rust in there.. Awesome help Thankyou very much!! Any good way to clean it well? Looks like it needs sandblasting .. Thanks again for sure!! Cheers Steve
Old 10-07-14, 05:46 AM
O
Received 11 Upvotes on 10 Posts
Here are some good instructions for the carb.
Disassembly, Cleaning and Repair of Walbro LMT Carburetor used on Briggs and Stratton Engines
I tend to spray thoroughly with carb cleaner, into every hole and orifice and blow hard with compressed air and then do it all over again and probably again. Peal the paper off of a regular twist tie (used for garbage bags) and lightly push that through the little holes and again spray with carb cleaner and blow with compressed air.
