Gas powered pressure washer won't start..
Old 10-07-14, 08:42 AM
H
I'm on my second Wel-bilt pressure washer. First one lasted six months and flat out wouldn't start.
The second one (that I receive as an exchange for the first one) will only start if the water hose is NOT attached. Also, when I attach the water hose and have water running, the water is not coming out the outlet where the wand attaches. I suspect something is clogging it somewhere and building up pressure with the hose attached.
I only ran it a couple of seconds without the water (I know I can't run it any length without water). I did check the inlet "filter screen" and it looks clean.
Any ideas what the heck is going on? Wel-bilt suspects the pump, and it "only" costs $129 (more than half what I paid for the entire system)!
Model# 157720
Thanks,
Andy
Old 10-07-14, 09:01 AM
cheese's Avatar
Received 146 Upvotes on 135 Posts
I'm sure it is a problem in the pump and a new one should fix it for a while, but these are low quality pumps and it might do it again. You probably have a stuck valve(s) in the pump and disassembling/cleaning it may help.
Old 10-07-14, 09:03 AM
G
Received 31 Upvotes on 29 Posts
Try a process of elimination, remove the pressure hose from the pump, turn on the water to see if water goes through the pump, attach the pressure hose without the wand, wand without the tip, etc. Have a good one. Geo
Old 10-08-14, 07:22 PM
H
geogrubb, I've tried those steps already. No water is getting through the pump. That's for the suggestion though.
Old 10-08-14, 11:31 PM
T
Well..when u have the water turned on and going in the pump at the same time cranking it..it will most likely not not crank..reason is...to much PRESSURE on the ENGINE..if still won't start..check fire..if blue..good..no spark..clean coil and set with any paper business card..or..carb may needs to be cleaned out..good luck..
Old 10-09-14, 08:57 AM
G
Try putting the hose on the outlet and see if you can back flush it some. Have a good one. Geo
