Oil leak - Older Craftsman Power Washer
Old 10-07-14, 02:28 PM
2
The power washer I own runs fine. It is a little finicky to get started (primer bulb is very stiff) but once running operates fine. Today I noted a sheen under the unit while it was running. Several times I stuck my hand under the unit and finally came up with oil dripping down off the pump. I believe that the crankshaft seal is compromised. I see no oil on the floor when the power washer sits. First question, is my guess on that seal reasonable? And, how difficult is it to replace the crankshaft seal if that is the problem.
Engine is a B&S 10B902 Type 0130 01
Thanks.
Old 10-07-14, 10:45 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
Yes, it's replaceable with minimal work. Remove the pump and use a seal puller to pull the old seal and an installer to drive in the new one flush. Be careful not to scratch the crankshaft... it is softer than you think. You can also pull the seal very carefully with a screw in a drilled hole in it, and put a new one in with a punch. Damage to the crankshaft is more likely this way, so care must be taken.
Old 10-08-14, 01:55 PM
2
Any idea where I can purchase an installer?
Can I pull the sump on this engine and replace the seal with a socket off the engine?
Old 10-08-14, 01:58 PM
Received 850 Upvotes on 746 Posts
I've always made my own out of wood when installing seals.
Old 10-08-14, 04:12 PM
G
Received 31 Upvotes on 29 Posts
Are you sure the oil is coming from the engine and not the pump, might not hurt to power wash the bottom of the engine and pump and watch to see where the oil is coming from. Have a good one. Geo
