bolt size for kohler 15.5 crank shaft
Old 10-17-14, 05:20 PM
Red face bolt size for kohler 15.5 crank shaft
I just installed a kohler command 15.5 engine on a craftsman riding mower went to put the pulley on , no bolt came with the kohler engine -wonder if it is metric or sae size would help and length, the old briggs engine bolt is thw wrong size thanks,
Model a
Old 10-17-14, 06:13 PM
Engines are available with different crank shaft profiles and threads. There is no standard. Do you know the model number of your engine that should allow you to find the crank specs.
Old 10-18-14, 01:09 PM
engine specs for 15.5 kohler
Model No. CV155
Spec No. 41508
Display-CC426
HP/KW 15/11.2
Serial No. 2405706974
Date on air filter case Nov.-93
Old 10-18-14, 04:06 PM
Here is a link to the manual, maybe it is in there somewhere. Have a good one. Geo
http://www.kohlerengines.com/onlinec.../tp_2339_d.pdf
