Do the oil seals on a briggs lawnmower engine sit flush with the housing?
Old 10-30-14, 03:30 PM
T
Briggs engine model 285707
It's a 12.5 (i think) HP, L head engine. My first teardown and rebuild... do the oil seals (one on blade side, and one on flywheel side) go all the way to the bottom, or do they sit flush with the engine housing at the top?
Here is a picture of each seal sitting flush with the engine, and hopefully you can see how much room is left underneath it.
http://i.imgur.com/NTBvhM9.jpg
http://imgur.com/NTBvhM9,SNC99lb#1
Old 10-30-14, 11:37 PM
hopkinsr2's Avatar
Press them in till they bottom out against the ridge in the bore you're putting them in... Roger
Old 10-31-14, 02:14 AM
cheese's Avatar
Received 138 Upvotes on 127 Posts
They don't necessarily fit flush and they don't necessarily bottom out... just as long as they are square or level in the bore, they are fine.
Old 10-31-14, 09:53 PM
T
Received 4 Upvotes on 4 Posts
Ok, thanks for the advice!
