Stubborn Chain Saw
Old 11-04-14, 04:49 AM
W
Received 60 Upvotes on 52 Posts
Stubborn Chain Saw
Husqvarna 36 chainsaw only used occasionally.
Used Stabil gas addative in fuel mixture.
Air filter and spark plug are clean.
Saw will nor start.
Sprayed starter fluid into the carb and saw ran for maybe 3 seconds.
Will someone give me a checklist of things to do to solve the problem? Thanks.
Old 11-04-14, 05:07 AM
the_tow_guy's Avatar
Received 177 Upvotes on 139 Posts
Check fuel line(s). When my infrequently used chainsaw craps out it's usually because the fuel line has deteriorated. Carb could need rebuild maybe, too.
Oh, and fresh fuel in tank, too. Just had that issue last week, hadn't used it for a while and had some old gas in it. Fired right up after draining and refilling.
Old 11-04-14, 05:09 AM
Received 742 Upvotes on 648 Posts
I second what TG said, I would have said it first but TG was quicker
also check the filter at the end of the fuel line [in the tank]
Old 11-04-14, 01:18 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
AND, don't use ethanol gas. Try to find an outlet for your small engines that sells non ethanol gas. It plays heck with the rubber parts and hoses, as well as the fuel cap if it is internally threaded.
Old 11-04-14, 01:45 PM
Good point! The last stihl saw I had died and it had low hrs, supposedly the fact that I had always used 10% ethanol played a part in it's demise I now know were all the 100% pure gas stations are and while it does cost a little more - it's not like you're filling up a 20 gallon tank
Old 11-07-14, 12:37 PM
W
Fuel Line
Fuel line is bad. Have new fuel line and filter on order. Thanks for the help.
Old 11-23-14, 11:25 AM
W
Fuel Line
Parts arrived. Replaced fuel line and filter. Problem solved. Runs good as before. Thanks to those who helped solve my problem. No excuse now. Have to cut the tree.
