Kohler 20 hp no fire to spark plug
Old 11-07-14, 03:44 PM
Have 20 h p Kohler on Cub Cadet that has no fire to spark plug. Where would be a good place to start?
Old 11-07-14, 03:47 PM
chandler's Avatar
Received 3 Votes on 3 Posts
Welcome to the forums. Probably the flywheel pick up or coil.
Old 11-07-14, 03:55 PM
Received 296 Votes on 270 Posts
How are you checking that you have no fire to the spark plug? Have you tried a different spark plug? Also check that the kill or grounding wire for the coil is not grounded via a broken wire or faulty ignition switch.
Old 11-07-14, 04:02 PM
Thank You, my first Kohler to work on.
Old 11-07-14, 06:27 PM
cheese's Avatar
Received 22 Votes on 19 Posts
Make sure the spark plug is grounded to metal on the engine when checking for spark. You didn't say which engine this is, but assuming this is a single cylinder courage engine from recent years, here is how to check it: If no spark with the plug grounded to the frame or engine, remove the engine shroud and unplug the kill wire from the coil and check for spark again. If not spark, the coil is bad. If there is spark, testing of the kill circuit is in order.
