Winterize - drain tank vs sta-bil
Old 11-15-14, 05:00 PM
R
I have a ride on mower and I want to to it away for winter. I'm so confused and read many sites, is it better to drain my tank or add fuel with stablizer.
if better to use sta-bil how do I do it? Fill my tank 100% full?
Old 11-15-14, 05:49 PM
G
Received 28 Upvotes on 27 Posts
IMHO:
No need to be confused, running it dry sounds best, however it never really runs completely dry and what remains evaporates leaving varnish which after doing it for a few years starts to create problems, so then maybe its better to leave it full of fuel which will fix the previous problem, however that would be great if the fuel was fresh which is never the case, its the end of the season and the fuel that gets added to fill the tank is the leftover from the mowing season which is already old. I say leave it full of treated fuel then drain it at the start of the next season and fill it with fresh fuel. Have a good one. Geo
Old 11-16-14, 04:47 AM
Received 821 Upvotes on 720 Posts
I always run my small engines dry but I do add some stabil to the last tank of gas.
Old 11-16-14, 05:33 AM
I treat my gas with Sea Foam. It has worked well for me as a cleaner and a stabilizer.
Old 11-16-14, 07:46 AM
Norm201's Avatar
Received 715 Upvotes on 636 Posts
I've done both. I find that at the end of season top off the tank add a fuel stabilizer and hope for the best. As Goegrubb says you will always have some residue left be dry or full. I prefer full only because I think it will stay in a liquid suspension longer and be less likely to gum up. BTW...I've never had a starting problem the following spring.
Old 11-16-14, 11:43 AM
R
if I leave it dry, should I use a air compressor to blow out the fuel lines?
Old 11-16-14, 12:08 PM
I never do, I figure the stabil added to the last tank will keep any of the gas from turning to varnish/sludge.
Old 11-16-14, 12:09 PM
G
Received 2 Upvotes on 2 Posts
No. Better to break the bank on a small bottle of stabilizer (it keeps from year to year) Add a little to the final run of gas and just run the engine until it stops. Tuck it to bed for the winter.
Old 11-16-14, 03:38 PM
R
If I poured too much sta-bil on accident would that do
any harm?
Old 11-16-14, 06:10 PM
Norm201's Avatar
No! It says right on the bottle that too much will not do any harm.
Old 11-17-14, 07:16 PM
cheese's Avatar
Received 138 Upvotes on 127 Posts
The best thing to do is to treat it and then even though you put it up for the winter, crank it once in a while. Small amounts of gas go bad faster than large amounts. The gas in your carb can go bad before the gas in your tank, depending on conditions. If you crank it up once in a while, you keep the battery charged and burn out what is in the carb, allowing new to enter from the tank.
Old 11-18-14, 10:21 PM
R
Thanks cheese you made me think of 3 questions
1. I plan on having my ride on mower in the garage, can I leave the battery intact without doing anything?
2. Is it ok to squirt wd40 in the spark plug hole? I know they mention oil.
3. How do I crank my engine after I lube my spark plug shaft.
Old 11-18-14, 11:44 PM
cheese's Avatar
You can spray wd40 in there but it's not necessary or really even beneficial. You can leave the battery in it except in really brutal conditions.
Old 11-19-14, 04:39 AM
I've never ever shot oil down the cylinder on any engine that was just being put up for a season. The only time I've ever put oil down a cylinder is when trying to start up up an engine that hasn't been run for years.
Old 11-19-14, 06:06 AM
Norm201's Avatar
Nuts! The only thing I forgot to do before the snow fell.
Old 11-20-14, 08:38 AM
T
Winterize
I have ran all my gas powered equipment dry the past 20 years as well as performing winterization maintenance for storage. I do use an enzyme stabilizer additive to gas during operation. My 20 year old MTD rider and other outdoor equipment have served me well so far baring mechanical issues other than fuel problems.
Old 11-21-14, 05:11 PM
R
Will my battery drain over time , if so how do if recharge it?
Old 11-21-14, 06:01 PM
cheese's Avatar
Yes, it will lose charge slowly over time. I battery maintainer connected to it will keep it up. It may not lose enough charge over winter to matter, depending on the condition of the battery and how it is stored.
