Auger Replacement Craftsman 27" Dual Stage Snowblower
Hi,
I have a broken auger to replace on this unit. I have separated the front auger housing from the snowblower and have taken most of it apart. I cannot get the impeller bearing off of the shaft, and it is too large of diameter to fit through the hole in the housing! any suggestions?
Thanks
Paul
Thanks
Paul
You mifgt have to rent or buy a gear/bearing puller. Sometimes you can borrow s puller from one of the auto parts stores.If you have the manual, you might be able to find the part # for the bearing, or you might be able to read the # on the side of the bearing. Look up donnyboy 72 on u tube, he has several videos on snow repair that will be helpful.
Sid
Sid
