ditch witch
ditch witch
I have a ditch witch 255 sx with a Honda motor it runs fine at a idol but if you try to move it loses power. any ideals?
Welcome to the forums! Do you have the idle set to high? It takes a lot to run the mechanics of the unit, so a high motor RPM is necessary. Can you engage the bar or move the bar?
This is only a guess. Is the carburetor housed? If not it may need a cover for the engine heat to keep it warm and not freeze up. My snow blower says to remove housing if normally used in temps above 40 degrees.
