MTD hydro transmission won't move
it ran and moved but i stopped in neutral and let it run but the n back out to it and now when i go to go fowards or backwards it makes a loud sound it is a mtd dont have any info trande for it has a hydrostatic transmissioni dont know what do is transmissinon sot
Welcome to the forums! Since this is nearly a 9 year old thread, it may be best to start your own thread with all the information off the name tags on the machine. It will help our tech people give accurate information. The moderator will also cut this loose from this thread and make a separate one, so get ready.
Yes, I moved this to it's own thread. Model would help, as would knowing what kind of noise you're hearing. It could be a stuck brake, stripped input pulley, or bad transmission.
