s-200 toro snowblower
Old 01-05-15, 10:49 AM
G
I'm having problems with gas filling in the air cleaner tube. when it sits it will drain the tank. I put a new kit in but it still does it
Old 01-05-15, 09:34 PM
Received 1 Upvote on 1 Post
Floats sticking in the carburetor, or the float bowl has a leak in it causing it to say down.
Just remove the bowl on the carburetor and lift the float up by hand and see if it totally shut off the gas when lifted.
Did you just change the parts or did you remove the whole thing and spray carburetor cleaner into the valve seat and all the other ports.
Old 01-06-15, 06:28 AM
P
Received 2,101 Upvotes on 1,881 Posts
You only said you "put a kit in it"??? What was the "kit" you installed?
Joecaption1 is on the right track. It sounds like you've got a float and/or needle valve that is not working properly. When gently lifting the float up it should completely stop the flow of fuel. Dirt, varnish as well as a worn needle, seat or leaking float can cause it to not work properly.
Old 01-18-15, 05:17 PM
G
today I took the carb off cleaned it again ordered another new kit again Put it in. still filling with gas. this carb has no float just a needle valve. replaced all of it.
Old 01-23-15, 09:03 AM
0
You are correct, this is diaphragm type I have similar model s620.
Did you install gasket in the correct order : main body , diaphragm, gasket and cover?
Did you install main seat with grooves into carburetors casting or out?
Old 01-29-15, 10:37 AM
G
s-200
I haven't looked for the grooves I'm going to look now. put gaskets in both ways have them right now.
