Tecumseh vector carb # 7
Old 01-07-15, 02:00 PM
T
After cleaning the carb & replacing some parts when I try to close it with the wire clamp it doesn't seem to seal properly with a gap between the plastic fuel bowl & the body. The plastic bowl does seem a little warped. Even when I just try to push it together with my hands it isn't easy to fit . Any suggestions?
Old 01-07-15, 05:29 PM
P
Received 2,107 Upvotes on 1,886 Posts
Make sure you have the bowl rotated to the correct orientation. The bottom on some has a high and low spot that must be correctly oriented so it doesn't hit the float.
Old 01-08-15, 09:44 AM
T
Thanks for the info, but it has pins so it will only line up one way. I have a new gasket also. It seems as though I can't compress the main nozzle tube enough, but it's the same spring,tube,etc. ???
Old 01-08-15, 11:28 AM
P
Short of saying go through and make sure everything is assembled properly I don't know what to say. Here is a website that has good pictures showing the assembly.
Old 01-11-15, 10:27 AM
T
Link
Thanks for the link. I will take some pictures to post to better show my dilemma.
