Trencher has water in muffler -buy or pass?
Old 01-26-15, 07:57 AM
1
Took a look at a trencher yesterday, 1974 Ditch Witch. Water came out of the muffler, the top muffler pipe danced around a lot (plenty of space for water to enter, and we've had lots of rain. Not sure how long the guy had it sitting out. Dug like a beast and the guy is asking $850.00.
Would you buy this thing knowing about the water, or pass?
I can change the muffler, add new tires, etc, for another $225 to $250. Luckily, he had a hard time starting it the first time and I think I could repeat the steps. Second time around, it started up on it's own.
Old 01-26-15, 08:19 AM
Rough Rooster's Avatar
Received 16 Upvotes on 12 Posts
If it cranked and was able to dig a ditch, then no worry about the water.
I see lots of slack in digging chain. Check to see if nose roller is worn. Chains and rollers are pricey items.
Rebuilt a nose roller last year by building up with weld and machining back to size. Also replaced nose roller bearing as it was locked. It was a common ag service bearing (used in disc harrows) that I bought at local JD dealer instead of ordering through DW.
If you have use for it the $850 is just a few rentals.
RR
Old 01-26-15, 08:23 AM
1
I think a week rental is $750 or so long as it lasts the week, I'm good. Have to dig 8 to 10 trenches on my property but also have a funky/unpredictable work schedule.
Thanks for the input, RR.
Old 01-26-15, 02:21 PM
V
Received 2 Upvotes on 2 Posts
Doesn't that vertical muffler have a little flapper on the top that prevents rain water from entering when it's not running ?
They make a little rattling noise at an idle; but are still worth installing .
Old 01-26-15, 05:01 PM
1
It has the flapper but the pipe itself, once you get past the actual muffler, is loose and dances around like a hula girl.
Old 01-27-15, 04:56 AM
V
Do you think the Seller would be insulted if you offered him $650.00? CASH ?
Clearly, he hasn't devoted much effort to preparing the unit for sale.
If you're in the ballpark, the worst thing that can happen is he'll say "No" !
