How do I remove this auger pulley?
Old 02-07-15, 09:30 PM
G
I'm trying to change the auger blade on my Murray snowblower. I can't figure out how to remove the auger pulley from the auger shaft. In the diagram, I'm trying to remove 0060 from 0070 so that I can pull out the whole assembly.
All the DYI videos I've seen show the pulley secured to the shaft with a bolt. This one seems to be secured using two tiny set screws (0110) which are impossible to get at. What the diagram doesn't illustrate is that there's barely a half inch between the pulley and the rest of the auger housing to get to these tiny screws, and they're recessed pretty far.
Any ideas? Maybe I just don't have the right tools? Or is there another way? Thanks
Old 02-07-15, 10:53 PM
P
Temporarily Suspended
2 Pc 22 In Long Reach Screwdriver Set
Maybe something like that.
Old 02-08-15, 12:08 AM
Received 3,196 Likes on 2,871 Posts
Welcome to the forums.
My Toro is similar in design. It uses the same two setscrews. Getting the setscrews out is easy. Getting the pulley to slide off the shaft is the trick.
You need to use a long 1/4" drive extension and an 8 point socket. I believe mine were 5/16".
With my blower.... I think I gained a little more space by removing the four auger support block bolts. Then slide the augers and blower shaft back towards the engine. Check the bearing that is right behind the pulley. I'm on my third one now.... but my machine is over 30 years old.
Old 02-08-15, 08:11 AM
G
Thanks for the response, looks easy enough.
