Primer not getting Gas?? After Carb Rebuid?
Old 02-13-15, 10:03 PM
biketrax's Avatar
Received 4 Upvotes on 4 Posts
I just rebuilt a couple snow blower Carbs (both Tecumseh a 5hp and an 8hp)
The 5 started right up!
The other however is not getting primer gas?? The primer button seems to be getting the suction however no gas is coming thru the hose? I ran air thru it to clear it seems fine? I am not sure how the primer gets its gas? I would guess there may be a yoke from the fuel line. Seems its very buried behind primer button, looks like a bear to take apart. will start to dissect next
Ariens 824 8hp
Snow is coming what's the next step?
Old 02-14-15, 05:26 AM
P
Temporarily Suspended
Is there any way you can bypass the primer & get some gas into the hose? Once it starts, it might clear the problem.
Old 02-14-15, 09:58 PM
biketrax's Avatar
Surgery was inevitable!
So I checked the primer line seemed clear? So it must of been the main fuel line.
I Took the pull starter shroud off and replaced both lines Fuel and primer! Problem solved ! Thinking some debris caught in the line!
Works awesome for the foot of snow that's coming!
Old 02-15-15, 07:18 AM
P
I'm glad that the problem is solved. Hopefully, the meteorologists will be wrong again, as usual.
