poulan 4000 chainsaw issues
I was given a Poulan 4000 chainsaw to buck some logs. The stupid thing won't start. I'm sure it's a carb adjustment issue. I've tried adjusting it from scratch but it won't even start to tune it. Any thoughts on what I can do?
Is this an old saw?
How often does it get used?
I've found it's more often then not trying to run it with old fuel or a dirty carburetor then any adjustments being needed.
A big help is to never run ethanol fuel in it or at least add an additive to counter act the effects of it.
Not going to use for a while dump out the left over fuel and let it run until it stops.
Sure sign of a messed up carburetor.
Does not take much to mess up those tiny orifices.
I do not even mess with trying to rebuild them I just replace them.
Air filter cleaned thoroughly and a brand new spark plug. Fuel line and filter might be a possibility. I was trying to avoid getting too in depth as I don't have a lot of spare time.
