low oil pressure light
Old 02-27-15, 01:46 PM
E
Received 7 Upvotes on 7 Posts
I have a 2006 Simplicity XL lawn tractor, 27 hp with a Kohler gasoline engine. It's been running very well so far and I even used it a couple weeks ago to move some snow. It has been sitting in my unheated shed since. Today I went out to start it up and even though it started without any trouble it wouldn't stay running. In order to start it the brake pedal must be depressed and normally you just let the pedal go and it stays running, but right now every time I let go of the brake pedal it shuts off. I have plenty of gasoline and the oil looks good but I get a low oil pressure light on the dash. The manual tells me that if that light comes on I should turn it off right away and contact my repair shop, but perhaps someone could tell me the problem or at least give me some ideas. We have had some sub zero temps the past couple weeks here in SE Pa. so perhaps that has something to do with it; I don't know. Thank you very much.
Rich
Old 02-27-15, 02:16 PM
Received 839 Upvotes on 736 Posts
You have checked the oil level, right? what weight oil is in it? when was the last time it was changed?
Old 02-27-15, 03:12 PM
P
Received 2,180 Upvotes on 1,950 Posts
You said it started fine when you had the brake pedal depressed. Then it quit when you released the brake. Is that when the low oil light came on? If so I suspect you might have the pto engaged or some other safety switch might be malfunctioning. The low oil light comes on because the ignition switch is in the run position and the engine is not running.
If the low oil pressure light comes on when the engine is running then there may be another issue.
Old 02-27-15, 03:26 PM
E
The oil level is fine and the oil looks good, too. I change the oil every spring so it was last changes last March or April.
Old 02-27-15, 03:31 PM
E
It is as you said. When the brake pedal is depressed the light is not on and doesn't come on until I let go of the pedal. When I let go of the brake pedal the engine shuts off and that light pops on. I will check out that pto switch tomorrow. Thanks.
Old 02-27-15, 05:33 PM
G
Received 2 Upvotes on 2 Posts
Look for snow that got onto/into the electrical circuits. May need a good thaw out.
Old 02-28-15, 01:21 AM
cheese's Avatar
Received 146 Upvotes on 135 Posts
Generally when a mower shuts down when you let off the clutch pedal it's because the seat switch is not working right. Try pushing the connector on tighter on the seat switch.
Old 02-28-15, 05:04 AM
P
I'm glad it's just a safety switch issue. It may be a bit of a bug hunt but it's pretty simple to fix compared to an engine that's been run with no oil pressure.
Old 03-11-15, 12:34 PM
E
Thanks for all the suggestions. It was the oil pressure switch which I replaced and the issue is solved. Thanks again.
Rich
