Fuel line diameter for a Tecumseh 4.5 hp enigine
Old 03-18-15, 02:00 PM
E
What diameter fuel line does a 2 cycle 4.5hp Tecumseh take? Fuel line is missing.
Model hsk845-8222c
Built 1999
Thank you
Old 03-19-15, 02:49 PM
W
Received 61 Upvotes on 53 Posts
Fuel Line
Measure the fittings where the fuel line connects.
Old 03-21-15, 05:08 AM
Received 3 Upvotes on 3 Posts
fuel line
Not sure how your fuel line is set up, but if it runs thru a hole in the fuel tank, you also have to be careful of the OUTSIDE diameter of the line. I've had fuel line that was the right I.D. for the fittings, but too small O.D. to seal where it went thru the hole in the fuel tank. Good luck-
Steve
Old 03-21-15, 07:28 AM
W
Primer Line
Hope this helps:
Tecumseh HSK845-8222C Parts Diagrams for Engine Parts List
Item number 351.
Found another example:
http://www.ebay.ie/itm/32180C-Primer...item5afe443f2b
Description says 3/16" ID.
