Husqvarna 150bt Leaf Blower Running Leaner - Harder to Start
Old 03-24-15, 08:34 AM
E
Blower is taking 3 - 5 pulls to start when it used to take 1-2. I pulled the spark plug and it has changed to very light shade of tan and was previously a darker shade, indicating a leaner mixture. There are air bubbles in the primer and takes 10x to remove most but not all bubbles. Primer does not appear to have any leaks.
A quick check of the fuel lines in the tank look OK, there is no obvious rot. Blower is 4 1/2 years old with 160 hrs. Should I just change out the primer bulb and fuel lines to eliminate possibility of small leak? Any other typical places to check this blower with a walbro wya79 carb?
Old 03-24-15, 08:47 AM
W
Received 61 Upvotes on 53 Posts
Blower
Check the spark arrestor in the muffler. It may be partially clogged.
Also, make sure the fuel filter is attached to the end of the fuel line.
