Briggs and Stratton 190CC 725EX Help
Old 03-31-15, 03:12 PM
A
I have a Troy-Bilt TB230 self-propelled push lawn mower with a Briggs and Stratton 190cc 725EX series engine without a primer bulb. I have had the law mower for about two seasons and have not had any issues before now. I finally decided to give it a go this season with the weather warming up. The tank was empty, so I filled it with fresh gas, topped off the oil, and tried to start it with no luck. I did a little research and have since replaced the spark plug, air filter, and carburetor (it was a fiasco in and of itself trying to figure out the appropriate part number for the carburetor). After replacing the carburetor, the engine will turn over and idle at a really low RPM (far more than it was doing before) for about a minute before turning off. While this is happening, the self-propelled mechanism will just barely creep the lawnmower along if you depress the lever. I've since tried inspecting the brand new spark plug again and it appears to be flooded with oil and gasoline. At this point, I'm out of ideas. I'm not very experienced with small engine maintenance and I'm really not sure where to go from here...
Any suggestions are much appreciated...
Old 04-03-15, 03:05 PM
G
Tough to respond if you can SEE the carb or mower. There is a spring that connects to the throttle on the top of the carburetor. Make sure this spring is in place. If the spring is not connected from the front of the mower to the throttle arm, this exact scenario of low idle barely running weill occur.
Old 04-03-15, 04:27 PM
cheese's Avatar
Does it smoke while this is happening? If so, what color smoke? Does the oil smell like gas? Is the air filter soaked with oil and/or gas?
