Lawn and garden equipment help
Hello,
It is that time of the year again for doing work on the yard and also time to replace some lawn equipment. I have a normal size lawn where my front yard is on a 15 degree or so incline. Last year I put down a Zoysia lawn, which is looking real nice. My only problem is is that my 2 year old personal pace Toro lawn mower sinks into the lawn as it is so plush and the "personal pace" has now turned into manual push. It was suggested to me from the outdoor equipment store where I purchased the mower from to cut the grass shorter and the mower would work better but it did not. My question is since my lawn is a normal size front yard if there is a better mower to use so I am not having to push the mower or do I just have to "man-up" and just bear with it?
Also, I am looking for suggestions for a new trimmer/edger. I have an old Black and Decker lithium battery string trimmer now where the battery is starting to go and it is not replaceable. I was looking at both gas and battery but since I only have a small yard I do not think I need a gas unit but am open to suggestions. I see that Ryobi makes good units but like I said I am open to suggestions. The edger I am looking for needs to have a blade as the string breaks too easy on a string edger.
Thanks for any help and suggestions.
I, too, would think there were height adjustments. I would absolutely NOT cut my grass shorter than 3 1/2". The blades will tend to shade the roots and keep them from scorching, and will keep water from evaporating. Shorter grass will turn brown quicker in a slight drought, too. Cutting grass that is wet from dew or rain can cause mower tires to slip, so make sure you are cutting in a dryer part of the day.
I don't use Ryobi tools in my business because of their inherent frailty, but for homeowner use, they seem to do pretty good. They have a edger trimmer that runs off their proprietary batteries, which, of course, are chargeable and replaceable should they go south. Cheaper than Dewalt, Milwaukee, and others, too. I agree, with a smaller tract, it would not be feasible to use a gas trimmer, considering storage of gas and oil for it. The battery operated units would suffice.
