Why is my Briggs and Stratton riding mower leaking fuel around intake valve now
Old 04-10-15, 10:32 AM
D
Whenever it's started it runs for a minute then gas spews out around intake valve and runs down on the exhaust
Old 04-10-15, 12:33 PM
Received 126 Upvotes on 111 Posts
How can you see the intake valve with the motor running?
Likly the float is sticking or leaking in the caburator.
Time to pull it apart, clean with carb. cleaner and a rebuild kit.
Old 04-10-15, 12:34 PM
P
Received 1,953 Upvotes on 1,749 Posts
Are you certain fuel is spewing out from your intake valve??? The intake valve is an internal part of the engine and not the sort of thing that spews fuel. Is it possible it is leaking from somewhere else like the carburetor? It would also help if you told us what engine you have (model number) or even if it's a overhead valve or side valve engine, one or two cylinders.
Old 04-10-15, 12:37 PM
O
Received 8 Upvotes on 7 Posts
Yeah, I bet you have a leaking inlet needle on your carburetor and what you are seeing is the fuel that has leaked into the combustion chamber and then into the exhaust muffler when you start cranking it.
Does the motor crank a few extra times now, before it starts?
Old 04-10-15, 03:45 PM
P
Three responses in a four minute window. How's that for timing! I guess Joe is the faster typer.
