string trimmer won't work
I have a Ryobi corded string trimmer. Off-on switch quit working after I changed from edger to weedeater attachment. Might power for second or two then quits. Any ideas? Loose connection?
Changing the head has nothing to do with the on, off switch.
Remove the head and see if it starts.
Far more likly it's a caberutor issue.
It could be the connection where the attachment meets the power handle. If it's been connected and disconnected a number of times the socket could be worn and the power prongs are too loose to provide a reliable power source. If that's the case it should power on/off by working the attachment back and forth with the power switch on.
A worse case would be if the trimmer attachment is defective and the powering on/off is coming from the motor inside the trimmer.
