B&S swap from tecomseh 13hp
Old 04-10-15, 04:14 PM
T
I am replacing my Tecumseh 13hp with a B&S 13.5 both are electric start on a Yard Machine lawn tractor. Can someone help me with the wiring?
Old 04-11-15, 04:40 AM
P
Received 2,180 Upvotes on 1,950 Posts
I suppose someone could if you posed a question.
Old 04-11-15, 05:20 AM
V
Received 3 Upvotes on 3 Posts
I don't know if it's still true; but because MTD makes so many mowers under different labels . . . . including Yard Machine, MTD used to provide multiple wiring diagrams within the common Owners Manuals, so that you could identify the differences depending upon whether the Unit was equipped with a Tecumseh or Briggs Engine. Never much of a difference; but different nonetheless.
I suppose now they'd have to provide diagrams for Honda and Kohler et cetera; butthe same basic principles still apply.
Old 04-12-15, 07:15 AM
T
Tucumseh B&S swap
How can I get an old Manuel
Old 04-12-15, 09:58 AM
cheese's Avatar
Received 146 Upvotes on 135 Posts
Look at the wires that connect to the carburetor solenoid and connect them to the new solenoid.
Find the wire that connects to the ignition coil and connect it to the ignition coil.
Same with the wires to the alternator and cable to the starter. The engines are generally similar as far as wiring goes.
Old 04-13-15, 08:08 AM
T
Tecumseh B&S swap
Thank you everyone for you help. The B&S engine should be here this week and I'll see how it goes.
