Deck Belt Replacement
Old 04-13-15, 12:22 PM
W
Received 41 Upvotes on 37 Posts
I bought a used Simplicity Sunstar Mower last year with a 60" deck on it ( Deck Model number 1691344) Mfg year 1995. I noticed while getting it ready for spring that the deck belt has a lot of cracks in it. Since this belt is driven by a gear box attached to a PTO shaft and then to the tractor, I cannot tell if this belt can be replaced without removing the deck completely. It almost looks like it might be (replacable without removal) but thought somebody out there may have done it once already and could tell me.
Old 04-13-15, 06:26 PM
cheese's Avatar
Received 138 Upvotes on 127 Posts
I looked at the diagram for this deck and it does look like it can be changed without removal of the deck. It's not a common enough mower for me to be able to recall off the top of my head.
Old 04-14-15, 07:22 AM
W
I will give it a try, as it looked like it might be changeable to me too. (John Galt was the hero from "Atlas Shrugged") Why did you want to know lol ?
Old 04-16-15, 10:02 AM
W
I called Simplicity, tech gave me a web site, and I downloaded an op manual that described the procedure. Manual wants the deck removed to replace the belt but I think this may be more for convenience rather than absolute necessity. It will have to wait for the deck belt that is on it to break before I determine the answer.
Old 04-16-15, 10:59 AM
cheese's Avatar
Yeah, many manufacturers say to remove the deck on their mowers to replace the belt when it isn't necessary.
Old 04-16-15, 11:46 AM
V
Received 3 Upvotes on 3 Posts
Originally Posted by WML13
". . . It will have to wait for the deck belt that is on it to break before I determine the answer . . ."
I wouldn't wait for it to break. Get the replacement and monitor the current belt closely so that it can be replaced at your convenience . . . . not when you're in the middle of some big job.
Old 04-19-15, 07:47 PM
W
I have a new belt on my tool box now. I have found parts for 20 year old machines have a habit of becoming "unavailable".
Old 04-20-15, 12:40 AM
F
Amazingly, the drive and mower deck belts for my fifty year old Sears rider (the one I am converting to electric) are still available from Sears. The unfortunate part is that except for basic hardware, the steering wheel, the rubber brake/clutch pedal pad and some kind of grass catcher all other parts are long obsolete and unavailable.
The lucky part is that I don't need any of the original parts.
