Gas powered pressure washer
Old 04-13-15, 03:55 PM
kolias's Avatar
Received 9 Upvotes on 9 Posts
Sorry if this post is in the wrong forum section
I’m considering replacing my electric pressure washer with one gas powered
I noticed that the PSI range is mostly around 2500-3000 and the GPM around 2-3GPM. What is most important to look at, the PSI or the GPM?
Mainly to be used around the house to clean the pave-uni double driveway and other odds & ends.
Last edited by PJmax; 04-14-15 at 07:09 PM. Reason: Moved thread to outdoor power equipment
Old 04-13-15, 04:30 PM
P
Temporarily Suspended
A gas powered pressure washer beats electric hands down. Those specs should handle all the things that you mentioned & more.
Old 04-13-15, 05:01 PM
Received 821 Upvotes on 720 Posts
.... and I wouldn't get hung up on PSI. You normally don't need an extreme amount of pressure and using more pressure than needed can get you in trouble [tearing up wood, forcing water where you don't want it, etc] Having a good engine [I prefer honda] and a good pump should be the primary concern.
Old 04-14-15, 01:32 PM
kolias's Avatar
Bought today a Simoniz pressure washer 3200PSI, 2.6GPM. Was on sale $200 less and like it because its compact, weights only 81Lbs, has easy to use controls and included 50 hose and dual soap dispensers. It comes with a 2 years warranty but it has a Kohler 3000 series engine (SH255, SH265) which I know nothing about it.
Anyone knows these engines?
Old 04-14-15, 04:14 PM
I've run airless spray pumps powered by 16 hp Kohlers and they were pretty stout. Do you know which brand of pump that pressure washer has?
Old 04-14-15, 05:55 PM
kolias's Avatar
It should be either SH255 or SH265 (3000 series), 6.5HP, 10.2 ft.lbs, 8320 CU, Heavy duty maintenance free axial cam. All this from the outside of the box. I have not open the box yet because on Thursday the new sales come out in my area and if I find a better deal I will return it.
Old 04-14-15, 07:04 PM
Received 3,886 Upvotes on 3,483 Posts
Looks like a bargain for the price. I like the two year warranty too.
Simoniz S3200 pressure washer
Old 04-14-15, 08:46 PM
kolias's Avatar
PJmax I'm curious which CanadianTire store this link refers to. The manual on the link refers to product 039-8595-6 and mine is 039-8578-8. The specs are identical but there are a few minor discrepancies when I compare the picture of the unit.
Old 04-14-15, 09:01 PM
That's not a Canadian Tire store link..... it's as you see it..... directly from the manufacturer.
According to Simoniz.... that unit is sold under two SKU's. SKU #039-8595 and SKU#39-8578
Old 04-15-15, 05:28 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You shop like my wife $200 less than what other brand? I have seen the Dewalt and others for about $600 to $700. Still sounds like a good deal, and it does have a quality engine, IMO, although I prefer Honda for ease of starting and quietness.
Old 04-15-15, 07:39 AM
kolias's Avatar
You are right Larry, I should have been more specific. I had no specific brand in my mind but my shopping list included a pressure range of about 3000PSI, 2-3GPM, compact / light weight, 50 hose if possible, and a connection to attach a detergent bottle. This was the only one fitting my specs including dual soap dispensers with a switch to select which dispenser you want to use (I like this feature very much). In addition a 50 hose cost $85 around here and since this one included the 50 hose that was an extra saving for me. Here is a picture of the unit
Old 04-15-15, 11:00 AM
I misread the price. I thought you said $200 for the unit...... not $200 less.
I bought an Excell from the Depot about 10 years ago. It had a Honda GS-200 (6.5hp) and a Cat pump on it. Cat is the Cadillac of pressure pumps. I paid around $500. I see prices vary widely and there are a jillion different units on the market.
Old 04-28-15, 09:54 PM
Piddler's Avatar
At Chandler, I like Honda engines too because I thought they were all quiet. I bought my pressure washer thinking that it wouldn't hurt my ears because it had a Honda engine. WRONG!!!! It's just as loud as B&S or Tecumseh. I was very disappointed with the noise. It does crank easy but takes time to warm up or it will die when you pull the trigger. Kind of cold natured. Once passed the warm up, everything is great except the noise.
Old 04-29-15, 01:58 AM
cheese's Avatar
Received 138 Upvotes on 127 Posts
Not all Hondas are created equal. The GX series is the pinnacle of small engines. The others with the plastic covers are just consumer grade engines like briggs and the rest.
Old 04-29-15, 06:37 AM
kolias's Avatar
Started the unit for the first time the other day and I was very impressed with the Kohler engine. Started with the first pull and very quite
