pressure washer wont start
It was working fine then it backfired once and quit. Using clean good gas. Upon trying to restart it runs for a few seconds maybe then just quits again. I drained the carb bowl and tried again, same result. Pulled the carb and sprayed all the passages good with carb cleaner, tried again, same result. Pulled the plug it looks fine. Engine fires then runs a second or two, no more, then quits. briggs/stratton. any suggestions appreciated. briggs/stratton.
Yeah like I said it'll fire, run for a few quick seconds, then quit. Same if I squirt bursts of starting fluid in the carb mouth during those few seconds. Won't keep running for more than two seconds or so. Seems to be compression okay I guess. ?
Temporarily Suspended
If the oil is a little low, there is a safety.
Or
Pull the plug & see if it smells like gas. Smell the oil too. If either of them smell like gas, it's flooded & the cylinder is gas washed.
Or
ok I'll smell, Pulpo. Actually the oil is a little low. guess I'll filler up good, then try. If still no go, I'll proceed to smell.
edit: ok I filled up the oil. made no change. pulled/smelled the plug, and smelled the oil too. don't smell like gas.
So how bad does the spark plug have to look before I might suspect it? Gap looks fine, is dry, just a little carbon looks used.
Okay guess what, I replaced the plug with a new one and and it starts/runs fine again. One thing that happened to the engine lately was the wire doohicky that is connected to the lever that you move to stop the engine broke and has remained disconnected, so in order to stop the engine I've been just choking the carb out all the time. So can doing that on a regular ongoing basis make the spark plug get fouled/carboned up enough to cause the issue I had?
I was going to suggest replacing the plug as I read this. Was it a NGK plug? Those are the worst about doing this. Flooding the engine to stop it could be contributing but most plugs can handle it.
Actually it was an Autolite plug. And the second replacement Autolite plug in a relatively short period of time/use. When this happened I thought naw couldn't be the plug 'cause I just replaced it not long ago. But sure enough it was. The appearance of these used plugs is blackend/carboned but other than that not particularly what might jump out as me as whoa that's bad, but apparently is. I really need to see if I can get that regular stop lever/switch fixed so I don't have to keep flooding the engine to stop it that way.
I haven't done it in about 40 yrs but I once had a lawnmower that the only way I could shut it off was to ground out the plug with a screwdriver. Fixing the lever would be best but shorting out the plug or removing the plug wire might be better.
I don't know what's wrong with them Pulpo, but something is because they give me more problems than any other brand. In fact, I think they give me more problems than all other brands combined. Some folks swear by them, I swear at them
(not really). Ever seen the thread about hondas that start and then shut down? It's several pages full of people having trouble with NGK plugs.
Not in my experience. El cheapo champions and autolites seem to hold up as well or better than any others from what I've seen. I don't have a favorite brand, but NGK is almost down there with the chinese no name stuff on my list. The domestic engines come with champions in them, and when I worked for the Dodge dealer back 20+ years ago, they came with champions too and I have seen some vehicles with plugs that wore the entire electrode off down to the ceramic and still kept running. I guess it all boils down to the accumulated experiences we have in our lives to form our opinions about these things.
