Coleman generator idling issue
Old 04-19-15, 12:09 PM
C
Any help would be greatly appreciated, I inherited a coleman 7500W generator with a briggs and stratton 14.5hp engine. I was told it had very low hours on it. When i received it blew smoke upon startup. I went through the whole thing, changed oil, filter, fuel lines, cleaned the carb out, spark plug etc. Yesterday it was running perfect but with a bit of smoke still. After checking a few other things i started it back up and now no smoke but the idle is jumping up and down. I made sure there were no intake manifold leaks and also cleaned the carb again just incase. Please Help. I have attached a youtube video of the generator running. Previous gas was drained from tank and replaced with new.
https://www.youtube.com/watch?v=Ns0ezJW-okY
Old 04-19-15, 12:26 PM
Received 3,619 Upvotes on 3,245 Posts
Welcome to the forums.
Your posted video is private.
You changed the carb out..... for an identical unit ?
You may not have gotten the governor set up correctly.
Old 04-19-15, 12:54 PM
C
thank you for your response, it is the stock carb. no swap out. i just made the video private, sorry about that
Old 04-19-15, 01:26 PM
I can see video now.
The governor is hunting. You may not have the linkage back in the correct hole on the carb or possibly a spring problem.
