Shear bolts ,snowthrower
Old 04-22-15, 12:01 PM
daswede's Avatar
Had the occasion today to winterize/summarize my snow thrower. On checking the bolts
I found one was bent,and very difficult to remove.
I'm wondering if i tightened the pin too tightly? I really snugged the pin bolt
Old 04-22-15, 12:15 PM
P
Received 2,116 Upvotes on 1,895 Posts
They normally only need to be snugged. You want it tight enough that the nut doesn't come loose but other than that it's not holding anything so it doesn't need to be tightened really hard. Still, over tightening will not bend a bolt. You probably hit something which was enough to bend the bolt but not shear it in half.
Old 04-22-15, 01:24 PM
Norm201's Avatar
Received 716 Upvotes on 637 Posts
Are you sure it was a bonified shear bolt? It should not take much to shear those. It's meant to do that. Could it be that someone or you may have installed a regular bolt by mistake or as a quick fix?
Old 04-22-15, 02:51 PM
daswede's Avatar
The shear bolts were the originals on the machine. I guess the answer might be closer to pilot
Dan's theory.
Thanks for your inputs
Old 04-22-15, 04:39 PM
Received 128 Upvotes on 113 Posts
Should be using elastic stop nuts so there not coming off and no over thighting needed.
Old 04-22-15, 07:18 PM
daswede's Avatar
Wink
I'm learning!
Thanks everyone for your inputs
