Electrical diagram
Electrical diagram
I need a wire diagram for a 2001 snapper hi vac with electric start 8.5 hp Briggs took apart and forgot to take pictures
Electrical diagram
Welcome to the forums.
A model number would be extremely helpful to eliminate guessing on our part.
Electrical diagram
I took my 2001 snapper hi vac apart and forgot to take pictures does anyone have a diagram or pictures very simple just can't make it work must be missing something
I don't have the model number I am installing it on a different mower now it is not a lot of wires and has no safety switches I have all hooked up the way I think it goes but when I turn the key nothing goes has recoil but just wanted to add electric to make it easier for me as I get older
I am not sure I understand exactly what you have done or are doing. Reusing a briggs engine originally off of a Snapper? On anther Mower?
If you are trying to wire a briggs engine for electric start, you can see where to find the model type and code here
If you are installing it on a Snapper rear engine rider
Snapper link
Either of those sites may also lead you to a manual or wiring diagram with a bit of digging.
Wipe the rear, horizontal area of the engine deck with a towel to reveal the model number sticker on a metal plate. Write down the entire number on the plate on a piece of paper with a pen. Model numbers are a mixture of numbers and letters and are 8 to 10 digits, depending on the model.
